Vibration at speed
Old Apr 3, 2021 | 10:25 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Vibration at speed
First, Camaro eye candy.
I am having an issue with a vibration that shakes the whole vehicle from 77 MPH to 86 MPH and smooths out a little bit at higher speeds. I have a relatively new set of tires on the car, and rebalanced them after the vibration appeared, and it had no impact. I will rebalance them at work anyways, but I am thinking that there is another issue going on and I am having a rough time identifying it and would love some ideas.
One area of concern is the driveshaft and rear end. The driveshaft is an aluminum unit out of a 2000 Trans Am that was totaled due to a front end collision, and the rear end is out of an 88 junk car with 3.23 posi and disc brakes. I put new brakes on the rear end, but otherwise is stock.
The alignment on the car is damn near perfect, and I have had it on my Hunter rack at work several times to ensure everything is straight. I am not sure what else, aside from front wheel bearings, would cause any significant vibration at just those speeds. I replaced the front brakes a few years ago, and repacked the wheel bearings last year and they were well within tolerance.
Any ideas what could cause a vibration at those speeds? Thanks as always!
Old Apr 4, 2021 | 09:04 AM
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
Re: Vibration at speed
Have you looked at the pinion angle ?
Old Apr 4, 2021 | 09:12 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Check u-joints, and it may not hurt to have the balance of the driveshaft checked.....
Old Apr 4, 2021 | 01:17 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Did it vibrate before you put those wheels on?...
Old Apr 4, 2021 | 01:37 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Was there one thing you changed that caused this vibration to start? If you made several changes at once, it's going to be difficult to single-out the culprit. If I were to guess, I'd go with the above-recommendation to start with the pinion/trans angle. If that's within spec, I'd look at wheel/tire balance and check wheels for out-of-true.
3rdgenmaro
Mar 17, 2024 08:21 PM
Colt
May 13, 2015 11:23 PM
n8sz28
May 31, 2011 11:39 AM
novatuc
Nov 21, 2006 06:04 AM
ZZ42Fast
May 11, 2003 03:52 PM
