What is the best oil for a high mileage 305??
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
One that burns oil on startup and during WOT there is a smell of burning oil after...what is the best one,or are there any additives to help reduce burning oil that ACTUALLY WORK???Cause I cannot afford a broken down engine in the next 6 months,damn colleg
Transmission: 4L80E/4L80E
I got started using AMSOIL while in college (married with two children to boot). I didn't have any engine failures while in college, and I ran at Scribner during those years.
The only potential issues are high consumption due to existing wear and/or hard seals, and a dirty engine when you switch over (petroleum oils will leave sludge and varnish in an engine which synthetics will tend to loosen, contaminating the oil). If compression is good, most likely you just need to change the valve guide seals to keep consumption in control. The sludge and varnish can be flushed before switching to synthetic, or just change the synthetic as it gets dirty.
Even in a worn engine, the typical synthetic is cheap insurance against total engine failure.
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
