Odometer quit working car running badly... stalling
My odometer quit working check engine light came on and the car won't run unless I keep the gas pedal at 1500 rpm's. The odometer started working briefly and everything returned to normal but quit again and same symptoms. 5 speed transmission. I"m thinking the VSS went bad.
Re: Odometer quit working car running badly... stalling
You have something evil going on with your electrics/electronics for sure, but whatever it is, it ain't the VSS.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Code 51 is a bad prom memcal. But can be the ecm not reading the prom and in limp home mode.
the Vss would be a 24 and cause stalling on deceleration or rapid stopping.
Well that makes sense considering the way the car was running? Would it be responsible for the spedo/odo not working also?
The memcal is the removable chip from the computer?
Engine: Lb9
Transmission: M20
Not sure what your working with but if 90-92 1227730 tpi or 3.1l if the ecm messes up it is a Vss buffer and could cause no output to the speedometer. The best guess would be a bad ecm or ecm ground over a prom loosing data. All f body ecms for thirdgen are removable and will transfer to a new ecm same service number or rebuilt superseded.
Engine: Lb9
Transmission: M20
I would check the grounds behind the passenger side cylinder head. If that’s ok and you still have code 51 I’d start with ecm replacement.
Thanks. I have a '91 Formula 5.7 so after I check the grounds and restart the '90 Formula if the same condition exists I'll swap out my 91 ecm to see if things change. really appreciate the help, really.
Engine: Lb9
Transmission: M20
The memcal chip should probably say aujp on it . These very rarely fail but if it has a piggyback adapter like Hypertech I e see those go bad or cause connection issues.
I pulled the ECM yesterday and everything was as you described. I took the ECM out of my '91 Formula and put the memcal into my ' 90 and took it for a ride. About 3 miles into the trip the symptoms returned. ( I'm guessing that when the ECM reached a certain temperature it malfunctioned). Back to my garage and installed the complete ECM and memcal from my '91 into my '90. It took about a minute for the symptoms to disappear and after 20 or so miles it runs fine. Looks like I need a new ECM.
Again, thanks for your help.
