Mahle 5746 head gaskets. What side up/down?
Old May 27, 2021 | 08:43 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Was going to put my heads on but the mahle 5746 gaskets don't have a marking for what side up or down. One side is consistent dimpled?, The other has dimpling and raised material around bites, water ports, etc..
Any suggestions?
Old May 27, 2021 | 08:45 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Mahle 5746 head gaskets. What side up/down?
My local machine shop uses them and honestly just sold me a set a couple weeks ago. He said numbers up is how they install them.
Old May 27, 2021 | 09:08 PM
NoEmissions84TA's Avatar
First pic, numbers up is the way I installed mine.
Now is the time to MEASURE your deck clearance.
Old May 27, 2021 | 09:34 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I did. It is .025". The mahle gasket is .028". Not much quench at .053", but with the someone dished piston I don't know what effect it will have.
Old May 27, 2021 | 09:43 PM
Vader's Avatar
I'm certain that there is a preferred installation orientation, but in reality we are sealing a casting against a casting. So long as the holes are properly aligned, I am betting that joint will be sealed either way. It is tantamount to someone accusing you of putting an O-ring in backward.
Old May 28, 2021 | 02:07 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I will install them writing up. At least that way the uniform surface is facing the block. Heads are brand new aluminum so shouldn't have a problem on that side.
Old May 28, 2021 | 07:39 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Heads almost installed. Gaskets writing up.
BLK MAJK
May 19, 2012 06:41 PM
drain89
Nov 6, 2008 06:25 AM
ejm
Feb 17, 2004 04:44 AM
sbc350
Feb 13, 2004 07:16 AM
nelliesIroc
Jul 6, 2001 07:52 AM
