I need help with cam specs.
Old Jan 16, 2002 | 10:58 PM
Torqomeo's Avatar
OK im looking at a comp cams 268 grind Xtreme energy Hydraulic camshaft. its adv duration is 224int, 230exh w/ 112 lobe seperation angle(LSA for short). Is this to weak for my 400 or will it be adequate for getting around on the street. and maybe a yearly trip to the speedlanes. I want to get into the low 12s with the 400.
I think im going to use the K-kits from compcams. I like warranties! I'm also going to use Sportsman II heads with 64cc. Im also using a roughly 9.6:1comp.ratio with Fel-pro Hyperneuetic pistons(thats probally wrong spelling but you get the picture)and hopefully a set of Lunati 5.7 Rods. As for induction for now the normal TPI will have to do. Yes i know it will kill it but i can't afford a Mini-ram or Super-Ram there are over $2000 Cdn funds so the stock will have to do for now. I'm going to have the crap ported outa them and slap on a 52mm TB and some new injectors. Well what do you all think anything i should change. All this is just background so you know where im coming from and where im going with it. Hope it helps so you can maybe help me.
Old Jan 17, 2002 | 02:21 AM
Torqomeo's Avatar
ttt
Old Jan 17, 2002 | 07:18 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
lift is .477 intake .480 exhaust
use 1.6s rockers if you can.
If you want the opening a closing timings that will take a little more work..
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
