85 Camaro will I need new motor mounts for a 360 small block
Re: 85 Camaro will I need new motor mounts for a 360 small block
A 350 will use the same mounts as a 305. They're both small block V8s. If that's what's in it now, you can re-use them. (or replace with new of like kind)
If the car is a 6-cyl, you'll have to change them.
