Need help with the car running rich. 89 Iroc, 305 TPI
Hi, I’ve owned this car for 2yrs…. 89 Iroc Z, automatic with a 5.0L 305 TPI. Overall the car runs strong but having some issues with it running too rich with a strong smell of gas and only getting about 100miles/tank. Also during start it blows bit of black smoke for few seconds. I’ve replaced many basic tune up related parts like: plugs/wires, O2 sensor, ICV, disconnected EGR, fuel pump, fuel filter, fuel regulator, replaced coolant, cleaned throttle body. My next plan is to replace the injectors and was told to install 19lb injectors. I wanted to know if I should consider replacing or updating any other parts while the intake and fuel rails are opened up during injector replacement?? Any help would be really appreciated!!
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Need help with the car running rich. 89 Iroc, 305 TPI
Disconnected EGR will cause you problems unless EGR is disabled in your tune. I'd consider reconnecting / replacing any faulty EGR components while you have the plenum off. A datalogger will help you diagnose poor running conditions. I recommend using the more expensive Delphi injectors as they seem to play nicer with the stock tune.
