88 gta carpet issue
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
88 gta carpet issue
I need to separate the thick underpad from my carpet floor is making them rust I just repaired and painted 2 coats
the carpets underpad feel wet
And I just want to know how to separate the underpad without ripping the carpet
the moist areas are passenger and driver legs well
ty
ty
Car: 86 Iroc-Z
Engine: 383 HSR
Re: 88 gta carpet issue
Um, have to ask... WHY are they wet? The carpet is not making it wet, water is coming from somewhere. Do you have a heater core leaking, or? Fix the leak and let the carpet dry, then fix the rust issue. Or destroy your carpet, I dunno.
Engine: 383 built
my whole intetior is flawless and I vacume my car ever week and I clean everything
the heatcore was charged 20 years ago
it doesn't loose coolant or anything.
I want to take the underpad out
just the foot area tell me how
Car: 1989 IROC-Z
Engine: L98 350 TPI
Your water leak situation isn't so flawless. It'll continue to rust if you don't fix that.
Engine: 383 built
Engine: 4++,350 & 305 CIs
You'll have to do water leak tests to find out..
Engine: 383 built
Same way you'd find a leak in anything exposed to the weather.
By pouring water all over the car and looking around and finding where it comes in.
You'll probably find it's the T-top rubber, like most all cars that have them.
Engine: LS1, LB9, L03
https://www.kt-s.net/media/T-Top%20W...k%20Manual.pdf
See page 14, assuming it's from the t-tops. Best method is to wait for it to rain hard, sit inside the car, and look for where the water's coming in. Remove trim pieces if you need a better look. You can also sit inside the car and have a helper spray the car with a water hose, but I find this isn't as good of a test as none of these cars are 100% waterproof, and it's easy to force water in with hose to a spot that would not normally leak under hard rain.
Car: 86 Iroc-Z
Engine: 383 HSR
Of all the leaky T-tops i have came across, they always seemed to soak the rear seats/floor/sail panel area. If this is where your water seems to be on your floor, I would check as the others have suggested. If the water is indeed in the front like I thought you had meant, I would definitely check the heater core under your dash. When these leak the water goes straight down in the area I though you were describing, and it is easy enough to get to and check. Wet front floors is a very common tell tale sign, especially on the passenger side. Hope this helped.
