Forget Everything You THINK You Know...
Old Aug 26, 2021 | 11:00 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
about motor oil, and camshaft break-in:
https://540ratblog.wordpress.com/
Old Aug 27, 2021 | 07:38 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Forget Everything You THINK You Know...
No one is going to read what seems like 100 pages
Old Aug 27, 2021 | 09:36 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I read... some of it. A lot of repetition about how great and awesome his tests are.
Cliffnotes about his claims:
-Don't run oil additives, just use a good oil (even with flat tappet cams)
-No need to run break in oil, just use normal oil.
-Use 5w30 if you can build enough oil pressure with it. Install a high volume pump if you can't.
-5w30 Quaker State Full Synthetic is #1
-5w30 Amsoil, Valvoline, Mobil 1, and Pennzoil Platinum (all Full Synthetics) are in the top 20.
-You probably shouldn't go longer than 5,000 miles on your oil.
Old Aug 27, 2021 | 10:09 PM
T.L.'s Avatar
And you know this how?...
Old Aug 27, 2021 | 10:49 PM
NoEmissions84TA's Avatar
I read it in the past. Komet summed it up pretty well.
I even took my own notes on his findings.
But oil companies are constantly changing their formulations.
What worked yesterday will not necessarily work tomorrow.
I personally try to use one of the better oils, but I do use the additive because then I KNOW it's in there.
Old Aug 28, 2021 | 07:13 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Based on what I see posted on several web sites concerning the ****-poor quality of many of today's flat-tappet lifters (probably manufactured from chinesium in some back-alley sweatshop), it wouldn't matter what lubricant/additive/break-in procedure is used---unless it's a roller, you're gonna have a problem.
Old Aug 28, 2021 | 10:17 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I gave up on studying various oils. Not sure what or who to believe. Lucas Hot Rod 10W40 oil in my old Camaro with flat tappets. Havoline 10/40 oil in the 88 with 4 ounces of Rislone zinc additive. Still wondering about aluminum bore lawn mower engines though.
83C_CamAroZ28
Sep 14, 2010 05:26 PM
Iroc_87
Feb 11, 2009 05:03 PM
formula forever
Mar 2, 2006 04:21 PM
