Upgrade Snow Performance Map Sensor?
Old Sep 1, 2021 | 08:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just upgraded to the VC-30 controller for the snow performance methanol system. The map sensor that is included in the kit seems to be a very cheap piece. Is there anyway to wire up a factory map sensor in place of theirs should quality be an issue? Here is a link to their setup.
https://hamptontuning.net/products/s...ntroller-vc-30
https://www.snowperformance.eu/en/wa...r-stage-2-vc30
Old Sep 4, 2021 | 09:45 AM
Vader's Avatar
Re: Upgrade Snow Performance Map Sensor?
I suspect the add-on system uses a MAP scaled for boost, likely up to 3 BAR (45 PSIA). The factory MAP is designed for 0-15 PSIA.
Old Sep 8, 2021 | 05:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I may be able to get away with a factory one if its possible. My motor should only be making somewhere in the 13-15 psi area.
Old Sep 8, 2021 | 08:32 PM
Vader's Avatar
15 PSIG (boost pressure) is 30 PSIA. That's double what a factory (non-blower) MAP can do.
SketchyZed
Nov 9, 2017 06:55 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
v8nate92RS
Apr 6, 2005 10:31 AM
