Grounding ECM
Grounding ECM
The schematic shows a ground from the ECM to firewall. I can not find the ground on the firewall. I at one time saw that there is a chart that tells and shows where , specifically, this ground. Where may i find such a chart? Thanks, Frank
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Grounding ECM
What schematic? Probably grounded to passenger side rear of cylinder head
Re: Grounding ECM
Several of the wires in the harnesses that connect to it, the black w white stripe ones, end up there.
Re: Grounding ECM
Regardless of the original/ Stock Ground location...
It would be ideal to have the PCM Ground connection terminate (directly) at the Negative-Terminal of the Battery.
The PCM 12V+ also should be changed/ moved to the Battery as well.
The Stock PCM Connections are something that we (Packard Electrical Engineers) overlooked back then (Sorry
Now we know better, and need to segregate the Dirty-Ground Connections, from the Clean-Ground Connections.
)...Now we know better, and need to segregate the Dirty-Ground Connections, from the Clean-Ground Connections.
