Need Advice: Oil pan leak
Old Oct 6, 2021 | 05:27 PM
HeavyChevy383's Avatar
I own a 85 camaro z28. Was told by previous owner the oil pan gasket is bad, and I noticed it leaking the past few days. I was hoping to fix it next year since it's a very labor intensive job.
I only plan on driving the car on the odd weekend. Will it be fine to drive even though it's leaking a bit?
any recommendations on a sealer or if I should use one at all?
Old Oct 6, 2021 | 06:18 PM
Re: Need Advice: Oil pan leak
Before getting all wrapped around the axle about pan gasket and labor intensive and all that other nasty stuff, check this hole and make sure there's a bolt in it.
If not, put a SHORT 3/8"-16 (std thread) bolt in there, maybe ½" long or at most ¾" with a washer or 2, with a drop of sealer on the threads. THIS YEAR.
Not sure what only driving on odd weekends would have to do with that; but w/e.
Better yet, who knows, you mighta got the car $1000 cheeeeeper than it would have been if it didn't leeeeek, which will make that bolt worth $1000.
Old Oct 6, 2021 | 06:22 PM
Will check that for sure! Thanks for the heads up, I didn't even know that was a thing. For the weekend thing I was just trying to say that I won't be driving it often
Old Oct 6, 2021 | 06:27 PM
Yeah, if you look in that hole, you'll see the fuel pump drive rod, if you have a mech FP. (which is why the bolt needs to be SHORT: it can clamp down on the FP rod and prevent the FP from working) In some blocks you can see the crank if there's no FP rod.
Matthew91-Z28
Sep 22, 2006 07:53 AM
DTL504
Mar 23, 2003 12:17 PM
zerotosixtyV8
Mar 1, 2003 01:32 AM
92 z28
Nov 23, 2002 07:20 PM
SX Stinger
Dec 27, 2001 08:01 PM
