Damn....oi leak after engine install. Whose fault?
Old Sep 21, 2006 | 07:50 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Well..I was so excited today. After a month of work, finally gor my 12" brakes, koni reds, and BMR tubular torque arm in. Then I noticedI have an oil leak at the front seal. I had the 305 removed and a 350 dropped in its place (in july). I told the shop to go ahead and re-use my 305 oil pan. Now I have this leak.
Am i responsible for this? I dont know if the bolts are torqued enough or if its a problem with the oil pan itself.
Old Sep 21, 2006 | 07:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
over torquing the oil pan bolts causes the leaks more than undertightening.
You can snug them up and see if it helps.
as long as the old pan wasn't totally fubared, it shouldn't leak, as long as the installer was competent. A leak at the oilpan - timing cover is kinda common, I think I have that. You can blame your builder if you like
Try dropping the pan, and seeing if the gasket is wet at the outer edge, that'll confirm if that's where the leak is. Then clean it, goop it in RTV and button it back up.
Edit - wait, if jesus built your hotrod... Who can you blame THEN? hahahahah....
Old Sep 21, 2006 | 08:52 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
there are 3 different front seals for sbc oil pans. a thick, thin and medium one. it all depends on the oil pan, as they had different cutout sizes for the front lip seal. an easy mistake is to get the seal for the 350, while the 305 oil pan may require a different seal. get a front seal for the year/eng size for the car the oil pan came from.
Old Sep 22, 2006 | 06:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I thought they were supposed to leak, keeps the pan from rusting
(same with valve cover gaskets, intake manifold end rails, and the oil pressure sending switch, nothing rusts. . . )
RBob.
Old Sep 22, 2006 | 07:53 AM
Sure it's the pan?
Is the smog pump still there?
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
