Where is the ECM located?
Old Nov 3, 2021 | 10:13 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
1984 Trans AM, 305 v8. My T/A is a u.s. build car for the Canadian market. Back in those years, our pollution laws on motor vehicles was much less restrictive. It has a cat. If this car had an ecm, which I think it does not, where would it be located?
Old Nov 3, 2021 | 10:19 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Where is the ECM located?
P/S under the dashboard. Wiring goes through behind the kick panel on that side. If your qjet has an electronic plug in the front p/s corner of it then you're guaranteed to still have a computer. I don't believe a single thirdgen left the factory without a ecm.
Old Nov 3, 2021 | 10:38 AM
72buickgs's Avatar
Car: 1984 Trans AM
There is no electronic plug on the carb at the passenger side. car would have been designated for "EXPORT" like the 1972 Buick GS I recently sold afer 21 years of owner ship. See photo
Old Nov 3, 2021 | 10:53 AM
For sure that isn't running an ecm then. The vacuum advance wouldn't be there either. Whether there's one under the dash or not is another thing but your engine certainly isn't using one.
Old Nov 3, 2021 | 01:32 PM
Yup, no ECM in an export. No sensors, misc solenoids, harness on the pass side, etc. either.
Old Nov 3, 2021 | 02:22 PM
72buickgs's Avatar
Car: 1984 Trans AM
I was in the process of removing the QJ to send it out for rebuild. I was taking reminder pictures to reinstall everything at carb install time.
GTA
Feb 21, 2010 09:02 AM
kenwa26
Sep 5, 2008 07:39 PM
Ripped
Aug 29, 2007 09:00 PM
eric305TPI
Nov 13, 2004 04:38 PM
