Heat Riser
Old Nov 4, 2021 | 06:45 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Heat Riser
I thought GM had done away with heat risers. Well, my '84 T/A has one & I will have to keep lubricated until, maybe next spring, when I can lift the car to remove the riser and then remove the butterflies.
Old Nov 4, 2021 | 07:19 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Heat Riser
The carbureted models had it. The fuel injected models just had a spacer. I had mine removed and now it functions as a spacer.
I don't know what kind of metal that valve is made of, but the guy who removed it for me had a hell of a time getting it out with a cutting torch. The holes were then welded shut...
Old Nov 4, 2021 | 07:58 PM
Re: Heat Riser
I cut the shaft with a wizz wheel, took out the remains, and put 1/8" pipe plugs in the shaft holes.
Then I took a die grinder to the inner diameter, and enlarged it to the full size of the manifold and Y-pipe.
Old Nov 4, 2021 | 11:12 PM
Vader's Avatar
Re: Heat Riser
There used to be a specific heat riser lubricant. Standard Oil (now Amoco) used to have a line of "Atlas" products, so I don't know who actually made it, but it seemed to work well. Back in the day I used it liberally on NoPar engines since they seemed to need it the most. A few squirts, then forcing the weight against the spring back and forth a few times, then a few more squirts, and it would rattle like brand new again for months.
I believe it was very heavily augmented with graphite, copper, aluminum, and molybdenum, so when the carrier/penetrating oil burned off there was something remaining to act as a lubricant - A little like antiseize lubricants.
Old Nov 5, 2021 | 07:59 AM
72buickgs's Avatar
Car: 1984 Trans AM
Re: Heat Riser
THe heat riser on my car, is vacuum activated.
Old Nov 5, 2021 | 09:24 AM
T.L.'s Avatar
Re: Heat Riser
Yes, we know...
Old Nov 5, 2021 | 05:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Heat Riser
Its only closed with cold eng starts. I cut mine out, cut the shaft/butterfly off, reinstalled the remaining piece, welded a washer to the stub inside. So it looked like all was there...on account of the smog man.
Old Nov 5, 2021 | 06:38 PM
72buickgs's Avatar
Car: 1984 Trans AM
Re: Heat Riser
Next spring, I will remove the heat riser and cut out the butterflies and plug the vacuum line.
Old Nov 8, 2021 | 07:40 AM
Vader's Avatar
Re: Heat Riser
...And the pivot still sticks like any other heat riser. Just keep it well lubed with something suitable for the application until you can "mod" it out if you choose.
Old Nov 8, 2021 | 11:30 AM
vorteciroc's Avatar
Top Answer: 1
Re: Heat Riser
GM now only refers to the product's original purpose in small print.
Old Nov 8, 2021 | 04:36 PM
nhgator's Avatar
Car: 1985 T/A
Re: Heat Riser
I had a thick International truck exhaust donut that was the perfect replacement for my heat riser valve,got it a the flea market for a dollar,worked for years until i installed headers.
72buickgs
Oct 21, 2021 01:18 PM
Tootie Pang
Jun 28, 2017 08:43 PM
dale3in98
Exterior Parts Wanted
Aug 24, 2016 04:08 PM
crazybird
Jul 19, 2012 09:51 PM
Gunny Highway
Apr 9, 2004 07:48 PM
