Replacing temperature sending unit
Old Nov 8, 2021 | 12:27 AM
Eric86TA's Avatar
Just got a 91 RS Camaro that the temp gage isn't working. I've found that what I think is the wire is disconnect and wrapped around PS pump lines. I want to just replace the sender unit while I fix the harness. Do I need to drain the coolant first?
Old Nov 8, 2021 | 03:10 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Re: Replacing temperature sending unit
I didn't... Expect to get spilled on a bit, and wear eye protection. Just need to be quick about screwing the new one in.
Old Nov 8, 2021 | 07:39 AM
Yup; it goes into the water jacket, and some WILL come out, but if you make good clear access to it so that you can work on it without fumbling around, and are READY (Teflon tape already wrapped around the new one before you pull the old one for example), you can get by with not losing too terribly much.
Ramair21
May 30, 2006 11:53 PM
92lt1
May 14, 2004 11:22 AM
Rod
Mar 4, 2004 08:46 PM
Speedemon171
Aug 3, 2002 08:07 AM
Fastrnu
Jan 5, 2002 08:11 AM
