Oil leak
Old Nov 11, 2021 | 08:11 PM
2names's Avatar
Car: 88' Iroc convertible
Transmission: 5spd
Oil leak
Hello, I'm working on my 305 which has a substantial oil leak. The oil pan is leaking bad enough there is oil all the way back to the tank. I pulled the tranny as I figured the rear main was also leaking so was going to do the whole deal. Inside the bellhousing was covered in oil but the rear main is dry. There appears to be oil coming from the frost plug right above the main.
My understanding is that coolant runs behind frost plugs so I'm at a loss as to what's going on here. Any help would be appreciated!
Old Nov 11, 2021 | 08:39 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Oil leak
That center plug is is the rear camshaft expansion plug. Coolant shouldn't be behind it, so the oil makes sense.
Old Nov 11, 2021 | 08:56 PM
2names's Avatar
Transmission: 5spd
Re: Oil leak
Thanks for sorting that out for me. Now what is the repair for a leaking rear camshaft expansion plug?
Old Nov 11, 2021 | 09:43 PM
Re: Oil leak
Come to think of it, I've never dealt with one while the cam is in place. Best GUESS is drill a hole center where the camshaft has a divot. Use a screwdriver to pry it out with that. Make note the depth of the old plug and make sure the new one seats in the same depth. I heavily suggest you search the webs for people's experiences.
Old Nov 12, 2021 | 07:43 AM
Re: Oil leak
Ditto aliceempire's repair description.
You'll find it difficult to come up with just that one plug, in all likelihood. I suggest getting a whole engine kit, which of course will include it; get a kit of this sort, with BRASS core plugs (they really have nothing at all to do with frost or freezing, except to the extent that they often fail under those conditions); and replace as many of them as you can get to, ESPECIALLY the 2 in the back of the block of course, while you have it in this condition.
I see what I would compare to a dripping faucet at the cam tunnel plug, but A GUSHING FIRE HOSE at the valve covers. That whole motor is DRENCHED SOAKED IMMERSED from the leeeeeeks at BOTH valve covers. You won't even NOTICE the one leak being repaired as long as the other is allowed to remain.
I also suggest you look at this hole right here.
If there is not a bolt in that hole, put a SHORT one in there, with a drop of sealer on the threads. 3/8"-16 x ½".
Old Nov 12, 2021 | 10:22 AM
2names's Avatar
Transmission: 5spd
Re: Oil leak
The whole plan is to do all the seals/gaskets so started with the bottom working my way up. Thanks for the info as I will take all the advice I can get for this project!
JTNKTZ
Dec 27, 2009 10:56 PM
Shadyredeyes
Dec 1, 2009 02:52 PM
adam86
Apr 16, 2006 11:41 AM
Vicious 88 GTA
Jan 19, 2003 07:51 AM
