Did I Screw Up the Oil Pan Gasket?
Old Nov 19, 2021 | 02:38 PM
Pnorth13's Avatar
Car: 89 GTA
Engine: 5.7
In the middle of a new cam/heads/timing chain swap. I have dropped the oil pan down as much as possible but still had to trip the lip on the back of the timing cover about 1" on each side - everything was filed down so no sharp edges. Did a few test fits and noticed that I had taken chunks out of the gasket on both sides. Note that I have the factory 1 piece seal. Am I an SOL and need to drop the oil pan and install a new gasket or will RTV seal this up?
Old Nov 19, 2021 | 02:56 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Did I Screw Up the Oil Pan Gasket?
IMHO you'll be fine. IIRC the cover seal gasket is a triple seal. It looks like only your outer seal is nicked. If I wanted to be more sure, I might throw some RTV just in that spot when I reassemble and let it dry for 24 hours. Gasket looks fine to me everywhere else.
Old Nov 19, 2021 | 03:09 PM
Pnorth13's Avatar
Car: 89 GTA
Engine: 5.7
Thanks - I can enjoy by beer now!
Yes only the outer ring of the seal is damaged. As for RTV, should I use the regular Permatex Black or the Permatex 'Right Stuff'?
Old Nov 19, 2021 | 07:47 PM
Engine: 350 TPI L98
Transmission: WC T5
Enjoy your beer! Well deserved doing a timing chain yourself. Have a second one on me. When I did my cover, with the oil pan in place and an OEM seal, I used the Permatex "Ultra Copper" at the ends. And NOTHING leaked. Let it dry 24 hrs before you start it.
Logan Bryant
Sep 29, 2019 02:09 PM
ANDYZ28
Jul 11, 2005 07:11 PM
StealthElephant
Apr 6, 2005 12:24 AM
Brett H. - 89GTA
Sep 12, 2004 04:58 PM
Surreal86z
Nov 29, 2000 12:02 PM
