LH Battery tray for Trans Am
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Anybody know where I can find one? Passenger side are all day long but no luck finding a driver side one. Tried classic industries, Ames, hawks, oer and web search…nothing. Or what have you done to replace yours on the driver side? Thanks all.
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: LH Battery tray for Trans Am
I am in the same boat as you. The Camaros only had the battery on the Pass side. Most birds also had the battery on the passenger side. Only TPI birds and Trans Ams got the driver side battery. Finding a clean used one out of a scrap Camaro is our only option at the moment unfortunately.
V6 Firebirds had the battery on the drivers side, and were built in greater numbers than their V8 counterparts, so should be easier to locate.....
Car: '89 GTA
Engine: ZZ6TPI
Used would be the only option. As was already stated, Camaros and non-TPI birds had the battery on the passenger side, so finding a good used driver side battery tray shouldn’t be too hard. I replaced mine with a used one from a Camaro.
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Perhaps you could use a pass side tray with some changes and modifications.
If you will use welds, you can cut & weld walls tray previous to install
BadBilly442
Feb 17, 2012 06:04 AM
