Tbi swap a carb
Old Jan 22, 2022 | 05:34 AM
Vázquez trek's Avatar
Tbi swap a carb
Hello, someone here has made a conversion of a 91 engine tbi distributor for a HEI type distributor (I don't know what to do to put my 305 engine with carburetor conversion on time) I hope someone can help meInformación Links please
Old Jan 22, 2022 | 10:14 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Tbi swap a carb
I see there's a language/translation issue here. What are you trying to do? Your car is a tbi and you want to switch to a carb? Or is your car carbureted now and you want to switch back to tbi?
Old Jan 22, 2022 | 05:54 PM
Re: Tbi swap a carb
my engine is tbi and I put a carburetor on it but I have problems with time
Old Jan 22, 2022 | 06:02 PM
Re: Tbi swap a carb
Then you'll probably want or a have a hei distributor like this and all you need to do is hook up 12volt power only when the key is on to the correct terminal in the cap. https://www.summitracing.com/parts/a...0/make/pontiac
If you are trying to use the distributor that came with the tbi then there will be no control on the timing advance.
Old Jan 22, 2022 | 11:06 PM
Re: Tbi swap a carb
exactly that is what i require to install a HEI distributor, do you know of a tutorial or steps to make that work
Old Jan 23, 2022 | 07:34 AM
Re: Tbi swap a carb
I'm still a confused on what you have or need an answer for.
You have a hei distributor like the link I posted, correct?
If yes, for the wiring to make the distributor work is just one wire that has power with the key on only.
Are you having problems putting the distributor into the engine?
maybe this helps?
https://youtu.be/vtbX5MVwVNY
Old Jan 23, 2022 | 07:02 PM
Re: Tbi swap a carb
maybe this helps?
I just want to remove my tbi electronic distributor and install a HEI distributor, but I don't know how to wire it up
Old Jan 24, 2022 | 04:07 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tbi swap a carb
Just like replacing any other distributor, can google search. The wiring from body side pink and white wire get hooked up to the side of the new distributor. Pink b+ and white is tach.
Old Feb 16, 2022 | 06:02 PM
Re: Tbi swap a carb
Hello, I am new to the forum, I would like to know what the function of the TACH is in an HEI distributor, since I have been told that it is not required to connect it for it to work and I wanted to know if what they tell me is true
Old Feb 16, 2022 | 07:19 PM
Engine: Lb9
Transmission: M20
Re: Tbi swap a carb
Tach is short for tachometer
jloomis95
Jun 25, 2012 09:16 AM
mr305
Carburetors
Feb 9, 2010 10:52 AM
86'ROC TPI
Jun 6, 2002 07:43 PM
RaGe
Carburetors
Feb 2, 2002 03:41 PM
