What is this Part & Purpose - in picture
Old Feb 23, 2022 | 10:23 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
1984 Trans AM 5.0 v8 Canada edition -
This part is located at the back of the intake manifold. I am mostly certain that it opens & closes, depending on the temperature of the manifold, to control intake manifold vacuum to the two attached vacuum hoses. One hose is attached to the cruise control hardware & the other is routed for the cowl induction hardware. Both hoses appear to have no other source for vacuum.
What is the name of this part?
In a couple of months I will be removing the intake manifold to repaint. That is when I will remove this part & check how it functions. It should have holes for vacuum output.
Thoughts..
Picture #1 is view from driver's side. Picture #2 is from passenger side.
Old Feb 23, 2022 | 10:28 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What is this Part & Purpose - in picture
Looks like just a nipple not a tvs
Old Feb 24, 2022 | 08:30 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Agreed. Does not look like any TVS I've ever seen. And that's a fairly common spot for a vacuum tee.
Old Feb 25, 2022 | 10:36 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
there's only vacuum where it screws in, no source of heat other than ambient and conductive.
Hector Ostia
Jul 10, 2021 07:08 AM
Ron U.S.M.C.
May 25, 2015 12:41 PM
Camaero
Feb 10, 2013 04:14 PM
SifoDyas
May 12, 2009 07:42 PM
kid camaro
Nov 18, 2003 08:22 AM
