TPI Fuel Rails
Old Mar 6, 2022 | 04:44 PM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
TPI Fuel Rails
I am in the process of cleaning out all the varnish and gunk from my 87 305 TPI fuel rails. I pulled the fuel pressure regulator off to replace it while I have everything part. I am in the process of disassembling the fuel rails to clean them out better and replace all the O rings while I am at it. Question is how do I separate the fuel pressure regulator block from the fuel rail. I tried to pull it apart like the front and rear tubes but the hard fuel line seems to prevent me from doing that. I don't want to bend anything out of whack that will give me problems later. Both of the hard lines are obviously
tied together with the mounting bracket at the end. Any insight would be greatly appreciated
Old Mar 6, 2022 | 05:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Fuel Rails
Hardlines are not serviceable. The fpr block pulls out it has a small aluminum spacer between it and rail.
standard motors sk24 works well.
Old Mar 8, 2022 | 06:16 PM
Engine: 87 5.0L TPI
Re: TPI Fuel Rails
Thanks for the information
88 5.7 Iroc-Z
Nov 15, 2016 02:10 AM
five7kid
May 24, 2016 01:31 PM
captainchadl
Apr 30, 2014 11:50 PM
89IROCZZ4
Sep 20, 2011 11:07 PM
