lifters hitting the block
Old Mar 15, 2022 | 05:30 PM
fat&furious's Avatar
Car: 1991 firebird Formula
Engine: super charged Lingenfelter 434
Transmission: turbo 400
Axle/Gears: 9 inch 4:30
i pulled the TPI off a 434 bowtie block. Going with a new solid roller cam and lifters but the lifters are now hitting the block..
Have any of you guys had to mill the block to make this setup work?
(I cant get my money back on the lifters i have so i dont want to spend another $800 on longer lifters if i can help it.)
I have been told milling the block is pretty standard so Im just checking to see if anyone has done this and had any issues
Terry
Old Mar 15, 2022 | 05:55 PM
Re: lifters hitting the block
Sounds like you have the wrong lifters.
They make taller link-bar lifters for that setup. (block set up for factory roller system, link bar type substituted in)
I WOULD NOT UNDER ANY CIRCUMSTANCES WHATSOEVER mill the block, no matter what. It's irreversible. The mistake of buying the wrong lifters can be reversed; cutting metal off your block cannot.
Manic Z
Mar 27, 2020 06:14 PM
TTAinthemaking
May 16, 2007 11:23 AM
Tibo
Apr 10, 2004 07:10 PM
CEDOE
Feb 6, 2003 02:18 PM
btheri3
Dec 17, 2002 08:08 PM
