lifters with block change
Old Apr 8, 2004 | 03:36 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am in the process of switching from a 305 roller cam block to a 350 roller cam block. I would like to save some money, so I know I can re-use roller lifters for a new cam if they are in good shape. My question is though can I use the roller lifters from the 305 block (and most fo the other roller related components) for the 350 block?
Old Apr 8, 2004 | 04:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
They are the same .842" - They can be used in the 350 block.
Old Apr 9, 2004 | 08:21 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Sounds good to me. I'll try and measure them. Are you talking about the lifter diameter or the diameterof the lifter hole in the block?
Old Apr 9, 2004 | 08:27 AM
ronterry's Avatar
Car: '94 Corvette
If they have some miles on them, I wouldn't use them. That's just me though.
Like any moving part, it's going to wear.
Ron
Old Apr 9, 2004 | 05:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Yes, you have a point but Roller hydraulic lifters have a much longer life then most other lifters.
Old Apr 9, 2004 | 06:08 PM
ronterry's Avatar
Car: '94 Corvette
'Tibo' if you have to ask or defend, than replace universal rule of thumb.
It would be different if they only had maybe 10,000 miles on them, but if they have 100,000!!!
Ron
Old Apr 10, 2004 | 03:28 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
do the roller bearings still roll smoothly?
Old Apr 10, 2004 | 05:48 PM
Tibo's Avatar
Car: 1991 Z28 Vert
They roll smooth and have no visual cracks or chips. I still have to look at them with a pair of magnifiers. Ronterry, I I know ,you have a point. They have 70,000 miles on them so they should last a little longer. I have heard that many people still have their original roller cam drivetrain and they have 200,000+ miles on it.
Old Apr 10, 2004 | 07:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
i think as long as the rollers operate smoothly and the pushrod seat can be pushed down and spring back it should be ok.
MoJoe
Sep 24, 2015 09:12 PM
db057
Sep 4, 2015 07:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
