Paper clip trick not working…
Old Mar 25, 2022 | 01:39 PM
86IROC112's Avatar
Car: 1986 IROC Z
Trying to pull codes with the paper clip trick. I’m not getting anything when A &B are jumped with the ignition in.
if I remember, it’s been a while, but I remember the fan coming on when I jump A&B. That’s not happening either. What should I do next?
thanks
Old Mar 26, 2022 | 07:14 PM
Vader's Avatar
Re: Paper clip trick not working…
Just for verification, the ALDL terminals are arranged like this, as viewed from the face (open) side of the connector:
Old Mar 26, 2022 | 11:39 PM
86IROC112's Avatar
Car: 1986 IROC Z
For some reason it worked today. It threw a code 21. High voltage from the TPS. I tested it and it was 4.75 volts with the throttle closed. Didn't change at all while moving the throttle. So I'm assuming the TPS is toast and would explain why its running like ****.
However, My fan is not working and according to the FSM it should be running when I jump A&B. ( And I remember the fan running in the past when I checked for codes) Where do I start when figuring out why my fan isn't working?
Old Mar 27, 2022 | 12:30 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Assuming you have an electric fan controlled by a relay, I would start at the relay. Fashion a jumper cable using two male spade connectors and wire of the same gauge that you are bypassing, pull the relay, and bypass the relay with the jumper for 2-3 seconds. If the fan turns on, your problem is with the relay, or the activation signal circuit to the relay. If the fan does not turn on, you have an open to the power or ground wires going to the fan, or the fan motor is dead. That isn't to say you don't have the previous issues at the relay or before as well, but I like to start by verifying actual fan workage.
Old Mar 28, 2022 | 11:21 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
What wire did you check tps voltage on ? Blue is feedback to ecm grey is 5v ref.
kittymum
Jan 2, 2014 08:08 PM
3rdGenIrocZ
Feb 28, 2009 08:12 PM
SX Stinger
Jun 30, 2002 10:08 PM
BIGJsTA
Oct 8, 2000 08:25 AM
