E4me quadrajet aftermarket support
Car: 1984 Camaro Z28
So I’m looking at getting my ‘84 back riding (oddly enough it gets better fuel mileage than my truck as it sat LOL). If I end up rebuilding it, I have to pull the motor up to replace freeze plugs, clean it up, motor mounts, and other stuff and if necessities don’t add up too much, stick a cam and some springs in. Is there any aftermarket computer support anyone has found to control this carb??? I know chips can be burned but I’d like to/not sure if it’s necessary to tune real time/live.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: E4me quadrajet aftermarket support
you won't find anything off the shelf that will control that system.
if properly adjusted and functioning the system will support a mild cam easily enough
