Fuel pump access door for 4th gen plastic tank in a 3rdgen?
Old Jun 3, 2022 | 09:33 AM
Blown_WS6's Avatar
Car: 1991 Firebird Formula
I just ordered a used 2002 Camaro plastic tank and am also wanting to cut a fuel pump access door while my interior is out. I haven't seen much information on what size and shape I will need for an access door when using a 4th gen tank and pump module and also how to adapt the pump module from the 4th gen to the lines of a 3rd gen.
Anyone have any info on these questions?
Old Jun 3, 2022 | 11:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Fuel pump access door for 4th gen plastic tank in a 3rdgen?
You really dont need it. The tank drops very easily since the filler neck is rubber and flexible so it’s literally minutes to get down and up.
but if you do, the tank opening is abit larger than thirdgen but the fuel lines are plastic and on quick disconnects unlike thirdgen hardlines so its easier to remove and maneuver
Old Jun 3, 2022 | 01:03 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Detroit Speed sells a kit that lets you have a sealed cover fastened down with screws.
That plastic tank has a pressure regulator integrated to the pump assembly at the return nozzle inside the tank. I think you're building your car step-wise with the final iteration being a supercharged stroker LS. Now is the time to ditch that regulator and build the full-flow return fuel system you're going to need for that engine, pressure sensors, and fuel quality sensors for alchohol content.
UKPROCHARGEDGTA
Oct 14, 2020 06:17 PM
kevwalt22
Nov 12, 2018 02:07 PM
scottwrightF1
Dec 27, 2017 07:00 AM
Jeromey Cummins
Fabrication
Dec 11, 2009 10:01 PM
tamatt27
Jul 17, 2004 04:03 PM
