Engine knocking/rattling
Old Jun 15, 2022 | 10:47 PM
Kyler_89RS's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi
Hey everyone! I’ve recently developed a rattle/knocking at what seems the bottom of the engine. It started while I was driving the backroads and I immediately pulled over and got it towed home. The car is holding good oil pressure and is idling fine. I pulled the dipstick and the oil was about a half inch low.
Here’s a video of the noise:
https://youtu.be/PU4A3sq80lU
Just seeing if this sounds familiar to anyone? I’m guessing it is going to need a rebuild which I don’t have the funds for, so praying it’s not that catastrophic of an issue.
Old Jun 15, 2022 | 11:13 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Engine knocking/rattling
Sounds like bottom end problem but check your torque converter bolts, make sure nothing is loose down there.
Old Jun 16, 2022 | 08:05 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Everything looks okay on the outside.
I changed the oil and the noise has toned down dramatically. Oil pressure is better. Would that be a good sign that it is a bottom end issue?
Old Jun 16, 2022 | 08:49 PM
Yeah, that pretty much makes it clear. If nothing external is contacting anything else then there's only one place it can be and they don't get better without some serious intervention
Mattkovitch
Feb 25, 2016 03:15 PM
Justinlf16
Nov 27, 2009 04:44 PM
AKATDOG
May 13, 2009 11:02 PM
ResonateEcho
May 21, 2006 11:00 AM
89Form-350
Oct 4, 2003 01:56 AM
