Glowing headers Even with Advanced timing? 383 stroker
https://imgur.com/a/IIgeMyQ
Headers started to glow on me after 2 minutes of running the car. I've been chasing a overfueling/rich condition for a while and wanted to try adjusting timing today but I noticed the headers on both sides light up red right where it connects to the y pipe.
Carb adjustments were 1.5 turns out and timing was at 16-18ish degrees.
Car has been running rich in the past (black smoke out of exhaust, having to hold pedal to floor to start)
Any ideas what this could be? I always thought retarded timing could cause this, but my timing is quite far Advanced at idle.
And yes my plug wires are on the correct order.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Glowing headers Even with Advanced timing? 383 stroker
The most common cause of such a condition is retarded timing. Have you checked the timing tab/balancer against #1 cylinder TDC to be certain you're setting the timing correctly?
