Mystery leak remains a mystery?
I got a strange leak at the rear of my engine. Happens right near the sending unit. I first thought it was the sending unit, which it was partially (got a new one and some of the leaking stopped, but it still leaks a lot. I then thought it was the intake, took it off, resealed everything perfectly, new distributor seal as well and just resealed the valve covers, and its still leaking. Now I am thinking the last thing it could possibly be is the standoff/npt fitting for the oil sending unit that goes into the block. Only thing is I can't for the life of me find one for sale. None of my local auto stores had one, nor did my local hardware store. I need a 90 degree fitting at the end.
Anyone know where I can get one? If this doesn't fix the leak I will be at a loss for words.
Engine info:
383 stroker,
rpm air gap intake,
edelbrock 6061 heads
msd 6a
msd pro billet dizzy
flowtech headers
Engine info:
383 stroker,
rpm air gap intake,
msd 6a
flowtech headers
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Mystery leak remains a mystery?
Did you use hi temp thread sealant on the npt fitting? Summit has a lot of fittings and adapter type stuff. I've also gotten fittings off ebay.
What did u search on summit? Brass npt fittings? 1/8 inch is what I need right?
