Time to change my plugs? With pictures.
Old Aug 31, 2022 | 11:20 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Hello,
My car is a 383 stroker, not a daily driver - in fact, it barely gets driven at all. I typically drive it once a week, usually for 30-40 minutes. I try to make sure to get a mix of highway and street time during my drives.
The plugs in the car have been there since 2013, but only have roughly 2,500 miles on them. I pulled one today and snapped some photos of it, see attached. I know it's only one, but they are a pain to get out with the headers on, and I didn't want to pull all of them until I have a plan in place, including the new plugs.
I'm leaning towards swapping them out but wanted some other opinions. Also, based on this one plug, does the heat range look correct?
Old Aug 31, 2022 | 08:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Time to change my plugs? With pictures.
I think they look real decent,but does look like you are sucking a little oil-probably through the PVC,possibly trough seeping valve guide seals.I'd stick them back in and run them.
Old Aug 31, 2022 | 09:49 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'd pull another plug and check.
Old Sep 2, 2022 | 07:13 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
What type? If they are a cheapy plug thats 10 years old, id just get a nice set of delcos and put those in
Old Sep 4, 2022 | 06:57 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
These plugs are NGK. I pulled a second one from the other side of the motor, and it looked about the same or maybe even slightly better.
However...I also read that Amazon had a problem with counterfeit NGK plugs, and if I remember correctly I think I bought these from Amazon. So, over the winter I'm going to swap them out for AC Delcos.
Old Sep 4, 2022 | 12:52 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Whatever you put in, apply some Anti Seize to the threads. Just a bit and do not get it on the electrodes. A little Silicone Dielectric grease, on in the plug wire boot, spark plug end. (You may already know this).
Bustionironi
Oct 13, 2019 08:40 PM
bensbaby
Dec 26, 2018 06:46 PM
Ozz1967
Dec 10, 2014 05:40 PM
kairles
Northern California
18
May 6, 2008 02:03 PM
paulmoore
Jan 3, 2007 01:26 PM
