Northern California Discussion board for Northern and Central California.
Pulled a coupe plugs this morning
Old 04-26-2008, 02:23 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
think this had something to do with my crappy last track outting.
pull 3 and all seem to be about the same, with a gap of about .042.
went and pick up spme new AC plugs and gapped the at .030, but I dont have the tools to change have of them. damn headers!
Im still gona race today, nothing else to do
Old 04-26-2008, 03:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Pulled a coupe plugs this morning
at least half the plugs are done!
Old 04-26-2008, 03:16 PM
kairles's Avatar
Engine: 383/LGX
I didn't change any of them
Old 04-26-2008, 05:56 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Is that aluminum on the plug? I can't tell.
Have you been able to watch your fueling at all? Do you have a scan tool? It would be good to make sure you aren't detonating under boost.
Old 04-26-2008, 06:03 PM
Axle/Gears: 3.73:1
Oh, and those Edelbrock headers really make plug changes harder? I hated changing plugs with the stock manifolds. The SLP's I put on made plug changes super easy. Of course I deleted the smog equipment so that gives me some more room.
Old 04-26-2008, 11:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
for the record, hooker super comps (long tubes) are all easy except for the #1 plug.
Old 04-27-2008, 04:15 AM
kairles's Avatar
Engine: 383/LGX
no sure what you mean about the aluminum, but it's on there not something that you can rub off. I only have the fuel pressure gauge and its goes a little over 80psi. I tried to datalog with tunerproRT but couldn't get it to record. on the street it runs great, even under part throttle in boost it runs good. even under full throttle it runs good up until 4500rpm then it starts to break up, and back fire. thats what made me think its ignition related. I would think im getting enough fuel volume with the 255lph intake pump and the inline pump. still haven't had the wideband installed, Im gonna try and get it installed this month.
Im about ready to just give up on cars anyone wanna buy an eclipse GSX I have all the parts that should fix it $800
Old 04-27-2008, 12:41 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Pics of the Eclipse? My brother might want it. What's wrong with it?
Old 04-27-2008, 02:32 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Be careful running your car. Your about to male a big donation to the aluminum gods. That is piston on the spark plug. Either the blower is blowing out the flame or the ignition can't fire it. It could also be the tune up is off. Either way it misfiring under boost is very dangerous.
That looks as if it is about to be really costly!
Old 04-27-2008, 02:59 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
heres ure problem close the gap up and run cooler plugs 2 step colder the cheap ngk v powers work fine ure flames being put out to much gap and ure plugs are to hot
Old 04-27-2008, 03:22 PM
kairles's Avatar
Engine: 383/LGX
I was thinking about getting 1 step colder NGK's(UR5?) but I read that lots of idleing and part throttle driving could couse the plugs to foul. this is my daily driver for the most part, I don't wanna be changing plus every 2 months.
Old 04-27-2008, 05:06 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
i run mines 2 steps and i run mines all year
Old 04-27-2008, 05:31 PM
kairles's Avatar
Engine: 383/LGX
I try the UR6's and see what happen, what kind of gap you think I should run? also I have a stock ignition system.
Old 04-27-2008, 05:50 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
gap them at .30
Old 04-30-2008, 11:58 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Replace em, runs a couple tanks of gas on them & recheck them.
Old 05-06-2008, 01:13 PM
Vash Vega's Avatar
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
so did you replace them if so hows the car running
Old 05-06-2008, 01:30 PM
kairles's Avatar
Engine: 383/LGX
ran great for about 4 min.
Old 05-06-2008, 01:42 PM
Vash Vega's Avatar
d@mn,what you mean by died like the engine threw a rod or stall out ect ??
Old 05-06-2008, 02:03 PM
kairles's Avatar
Engine: 383/LGX
that is a link click on it
xbmx89
South Central Region
10-31-2015 10:59 AM
AmorgetRS
Convertibles
08-31-2015 11:55 AM
TMoNeE
Northern California
08-24-2015 06:11 PM
Bert87
08-23-2015 03:50 PM
apie2546
08-10-2015 05:43 PM
Quick Reply: Pulled a coupe plugs this morning
