Oil pan leaking again from rear.
Old Sep 20, 2022 | 12:17 AM
caddyescalade's Avatar
I have a one piece felpro oil pan gasket that is leaking again by the rear seal. I’d really rather not go thorough all the trouble to pull the pan again for a small dripper. Has anyone had success just loosening the bolts enough to drop down the pan a bit to add some rtv? I think the felpro gaskets are reusable. I’m thinking it’s probably imperfections in the old pan itself is feuding the leak. Thoughts?
Old Sep 20, 2022 | 06:28 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: Oil pan leaking again from rear.
Yes I have. I haven't done it on a thirdgen oil pan but in many areas of many other engines. And I've reused gaskets old & new.
Old Sep 20, 2022 | 08:25 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
will the RTV seal it if the gasket and pan have oil on them? I agree it is quite a job pulling the oil pan for such a small job.
Old Sep 21, 2022 | 03:11 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a canton road race pan, one piece gasket, and factory pan rail supports and I still have to run a skim coating of rtv on the top and bottom of the whole gasket to keep it from leaking. Make sure you get it around the pan bolt holes.
Old Sep 21, 2022 | 06:05 AM
BBCSwap's Avatar
[QUOTE=yankeecarman;6480133] will the RTV seal it if the gasket and pan have oil on them?
Wipe off any oil and it should seal but sometimes problem areas don't do what they should.
billybob6110
Nov 1, 2016 06:52 PM
brsaye
Feb 18, 2013 06:38 PM
StealthElephant
Apr 6, 2005 12:24 AM
92 z28
Nov 23, 2002 07:20 PM
Surreal86z
Nov 29, 2000 12:02 PM
