Runs like garbage when warm
Car: 1991 Camaro RS
Engine: 3.1 V6
Hey guys so I have a 1991 Camaro with the 3.1 V6. When I first leave my house in the morning it runs great for 5 to 20 minutes (great low end power and acceleration, good idle) until the engine temp gets up. After that it loses acceleration power and has idle surges/sometimes stalls. The big thing is when u hit the gas kind of hard it just has 0 power (haha yes i know its a v6 but its runs awesome when cold) The cooling fan also never comes on but I bypassed the sensor to make it work.
Things I've done so far -
O2 sensors
EGR valve
ignition tune up - plugs, wires, cap and rotor
fuel pump
all new injectors
cleaned throttle body opening by throttle flap
Coolant temp sensor in intake for ecm
and in regards to the fan i checked all relays and fuses. they are good.
Any help is greatly appreciated thanks guys!
-Nick
O2 sensors
EGR valve
fuel pump
all new injectors
-Nick
Car: 1991 Camaro RS
Engine: 3.1 V6
Engine: LS1, LB9, L03
Re: Runs like garbage when warm
Have you checked the timing? I had similar symptoms on a TBI 305, replaced damn near every sensor and tune-up part on the car before thinking to double check the timing that my co-worker set it at (which was wayyyyy off).
Car: 1991 Camaro RS
Engine: 3.1 V6
No I haven't messed with the timing at all. might be a good idea to look into. Just dont understand why it runs perfect when cold.
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
heat affects ignition control module. Been a problem for me more than once! When all else looks correct it's the first thing I change. Use correct lube when installing or it will fail quicker then it normally does
pinky101
Jul 4, 2011 10:19 PM
greenirocz
Aug 28, 2006 11:01 AM
