Oil pressure switch
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Oil pressure switch
Which oil pressure switch feeds gauge? One next to distributor or above fuel filter?
Engine: 5.7 l98
Engine: 5.7 L98
Re: Oil pressure switch
Avoid the AC Delco, I had 2 fail quickly, bad readings even by gauge standards on one and a leak on the other. The car quest/wells WVE 1S6569 has been great and is much more accurate as verified with a mechanical gauge. Rockauto has it for $17
Engine: 5.7 l98
thanks for the good info
