Gas tank vent valve
Old Oct 8, 2022 | 03:39 PM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Gas tank vent valve
So when I take the cap off my car it hisses like it's not venting. Is it just the vent valve under the car. It also seems like it doesn't get quite enough fuel, could that be helping to cause that issue?
Old Oct 8, 2022 | 04:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Gas tank vent valve
That is normal. The tank retains some pressure as it vents through the charcoal canister. Which is controlled by a vapor pressure valve.
Unlike older cars our f-body's have a closed fuel system. Along with all (nearly all?) cars of this era.
As for not getting enough fuel, how can you tell? Fuel filter changed in recent months?
RBob.
Old Oct 8, 2022 | 06:25 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
My '82 Recaro T/A was doing this and it turned out to be the purge solenoid for the charcoal canister was inop and stuck in the closed position.
Old Oct 8, 2022 | 06:28 PM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
RBob.
No it's never been changed, and I have the 2.8 mpfi and it just bogs all the time and in the morning especially it misfires horribly, and want's to die, idling real low than hmgets high again, didn't know if it was a fuel issue. Also my sending unit or fuel pump or whatever is pretty noisy, is that normal for these cars? Because in other Chevy I've been in, mainly the 2000s trucks when the pump is loud it means it's going out.
R-Dog
Aug 24, 2019 11:30 AM
Strick1
Aug 27, 2015 08:57 PM
camaro1992
Jul 27, 2007 10:33 PM
91 zedder
Aug 10, 2004 04:28 PM
3.8TransAM
Dec 27, 2001 01:23 PM
