bracket/accessory setup for 1986 TPI
Old Oct 16, 2022 | 05:40 PM
keithl1967's Avatar
Anyone have any photos/suggestions for mounting the AC compressor/power steering pump with headers?
I am running the SLP (just installed) headers, and the OEM bracket for the front driver's side is no longer useable.
Old Oct 16, 2022 | 06:38 PM
Re: bracket/accessory setup for 1986 TPI
This is the general principle. Different brand of headers, same conundrum. Stock hardware with a spacer, which you can make yourself out of pipe parts (medium length nipples heh heh heh heh, maybe ¼" or 3/8" pipe) that you can pick up at the hardware store.
https://www.thirdgen.org/forums/atta...-side-view.jpg
SLP sold a modified stock AC bracket for use with their headers that had the rearward one of the 2 bolt holes cut off and re-welded farther out from the head. The #1 tube interfered with it in some setups, to where it couldn't be used as-is.
Old Oct 17, 2022 | 07:26 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Hedman has instructions on how to modify the stock bracket.
File Type: pdf
snipe04
Aug 18, 2010 12:00 AM
Josh R
Aftermarket Product Review
May 17, 2008 11:18 PM
TransAmTBI
Jan 27, 2003 10:54 PM
iroc5speed
Dec 30, 2001 10:17 PM
