a/c delete power steering bracket needed v-belt setup HELP!!
Old Dec 30, 2001 | 05:10 PM
iroc5speed's Avatar
ok, title pretty much sums it up. I need a power stering bracket for a non a/c car with v-belt. Anybody know a part number?
Old Dec 30, 2001 | 05:34 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Re: a/c delete power steering bracket needed v-belt setup HELP!!
Good Luck. If you find out please let me know. I just recently swapped to a 355 in my 86 TA and eliminated the AC. I ran into the same problem you have. At first I was just going to hook the AC bracket back up without the AC on there just so I could use the power steering pump. Well, when I tried that I found out I couldn't do that because now the AC bracket won't fit due to the headers I put on there.
I had to make a custom bracket using part of the smog pump bracket since I eliminated the smog pump. The homemade bracket worked for about two months but it's too weak and now I have problems with my power steering at low rpms.
I went to the local parts store and they suggested A. going to a salvage yard and getting a bracket off a non-AC car or B. going to a welding shop somewhere and having them make me a custom bracket.
I think if I could find the part number for the non-AC bracket I'd just go ahead and order one from GM.
Old Dec 30, 2001 | 10:17 PM
MotorCityMuscle's Avatar
I have one from my 85 Sport Coupe. I might let it go for a few bucks. E-mail me at DunawayD@twmi.rr.com if you want.
Terrell351
Jun 13, 2021 01:13 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
