Starting issues
Old Oct 20, 2022 | 10:43 AM
ajg89's Avatar
Starting issues
Car was starting and running, then struggled to start, and then out right stopped cranking.
The Haynes repair manual indicated a faulty starter so I swapped that out for a new one and still nothing. Swapped the starter relay as well and still nothing. The neutral indicator has been bypassed (unsafe, I know.)
Connected the multimeter on the thin wire from the key indicates constant battery voltage. Both starters were verified to be working. If I had to guess I’d say the the ignition switch itself is not functioning but that doesn’t seem the case because all the instruments react accordingly.
Old Oct 20, 2022 | 09:39 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Starting issues
Turn on the headlights and try the starter. IF the lights go out, might stay out even, you need clean the battery and cable terminals, or a new battery cable.
Jordan Dorn
Jul 10, 2017 01:49 PM
wilkink
Dec 8, 2013 05:10 PM
camar0rs
Oct 27, 2012 12:32 PM
devildogwp
Sep 4, 2011 02:39 PM
sunbitz
Jun 29, 2003 09:34 PM
