1989 TBI serpentine bracket set-up
Old Nov 23, 2022 | 11:14 AM
taguy16's Avatar
What was the serpentine bracket set-up for 305TBI engines without A/C? Someone put a truck 5.7 engine in the '89 Camaro I got which I believe has brackets that sit too high to be used in a car, so I'm trying to figure what I need to put it back to the car serpentine set-up. I believe there was still one large aluminum bracket that housed the alternator and power steering pump (that was specific to cars), but I'm needing to know if there was a separate one for the belt tensioner (and pulley) or whether this also attached to the previously mentioned bracket in non-A/C cars, since they wouldn't have had the A/C bracket to attach it to like the A/C equipped cars did..
Thanks for any help.
Old Nov 23, 2022 | 11:22 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1989 TBI serpentine bracket set-up
https://www.ebay.com/itm/26598661027...mis&media=COPY
Old Nov 23, 2022 | 11:23 AM
Engine: Lb9
Transmission: M20
You can get a a/c delete pulley if needed, pulley offset is different as well with tbi trucks.
Old Nov 23, 2022 | 07:31 PM
taguy16's Avatar
That's for a car with all the bells and whistles. I'm sure GM wouldn't have installed all those parts on a car with no A/C or air pump, because that would have been extra production cost for them. There had to be a way to mount the tensioner/idler pulley without having to have all the stuff shown in that listing.
Old Nov 23, 2022 | 07:34 PM
Engine: Lb9
Transmission: M20
For non a/c they just had a delete pulley same as tbi truck. Two different styles of delete for air.
Old Nov 24, 2022 | 10:11 AM
taguy16's Avatar
It must have been easier for them to do it that way because it doesn't seem like a good design to be turning pulley that don't do anything except hold the belt. Seems like extra friction, not to mention an extra fast moving part to wear out eventually.
evilstuie
Apr 20, 2016 02:43 PM
irishhockey34
Mar 14, 2013 07:06 PM
NullHead
Mar 1, 2012 02:17 PM
jamon8
Jan 11, 2010 08:45 AM
mattsv8_03
Dec 25, 2008 09:26 PM
