Single pattern cam or dual pattern?
Old Dec 2, 2022 | 05:02 PM
  #101
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: Single pattern cam or dual pattern?
Originally Posted by F-BIRD'88
Yup you got the story.. We are all waiting on cams pistons bearings and more.. The supply chain all over is a big mess..
That TFS track max cam: If you want to run high ratio rockers on it be sure your valve springs are up to that job.. The rocker ratio has a multiplying effect on the VALVE MOTION. it multiplies lift AND it multiplies Valve motion open close acceleration/ deceleration... ( The valve moves quicker faster farther open close) This needs better valve spring control.. Thats why the LT-4 engine and the high perf LS engines use light weight valves..
as the OEMs like to run as little valve spring seat/ open force as they can get away with.
Standard weight valves with high rocker ratio will need more spring force fir X rpm limit.
That TFS .530" lift cam I would stay with a 1.5 rocker ratio on that one for the street. It still needs good springs . There is no free lunch in all thus stuff. Increased valve motion needs better spring control.
If I go that route I'd likely stay with the 1.5. There's a Chevy NAL-10185071 cam as well that I would use 1.6 with. The thing that concerns me with the TFS is it says it wants a 10.5 comp ratio. That ain't happening. Also a lot of them say NO when it comes to computer control. So I don't know how accurate a statement that is. Seems a lot of guys are running cams like that with TPI
Old Dec 3, 2022 | 10:09 AM
  #102
skinny z's Avatar
Some advice on regrinds from Jones:
https://www.speed-talk.com/forum/vie...hp?f=1&t=65078
Old Dec 3, 2022 | 11:00 AM
  #103
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I ordered a Lingenfelter 74211 along with 1.6 Rockers. Thanks for all the input. I've learned the following hierarchy:
1: Selecting a Camshaft
2: Nuclear reactors
Old Dec 3, 2022 | 11:04 AM
  #104
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Yes.. The exhaust lift is not that critical on a sbc.
on the exhaust side it is all about the duration and thus actual exhaust open close events.
Thus a 1.6 in/ 1.5 ex ratio set is very popular.
.net .528"/.503" at the valve.
Its the intake side on a SBC that benefits by using increased intake rocker ratio for more intake valve lift..
Especially if when the cams intake duration is mild as these ALL are.
The LT-4 cam will run fine with 1.5 rockers.
and should benefit from either a 1.6/1.5 set or 1.6/1.6.
Onany cam like these ALL if you want to tame the overall net effect of cam OVERLAP a bit,
then choose the lower 1.5:1 exhaust side rocker ratio.
(1.6/1.5)
This tames the idle just a hair.
You can also advance the cam a bit too to tame the idle vaccum a hair.
EG the hot cam is 109/115 centers (112 LSA) thus its 3 degrees advanced.
To close the exhaust valve a hair earlier advance that cam a but more to say 107/117 centers. its now 5 degrees advanced.. The combibed effect will tame the idle vaccum a small amount if that is critical.
Same same with the Melling cam. eg 104/116 centers. Exhaust valve closes a hair earlier..
If the GM LT-4 cam DOES run in these TPI engines with the GM computer I'd say all these others will also. They are all very comparable.
If it is known that the GM LT-4 hot cam causes the TPI computer to foul up the drivability then all these other very similsr cams will also likely cause same issues.
I cannot see it needing more than a change in the base timing and basic timing curve a bit.
( You want the same same max WOT spark timing.
SBC 34-36 deg BTDC @ WOT rpm.)
All these cams will like increased base idle timing to idle best and creat the best idle manifold vacuum. All of them.
with tuning the GM computer can handle a LT4 Hot-Cam, or any other cam of similar specs. The LT4 Hot-Cam isn't wild by any stretch of imagination.
Something like what I'm running with 66° overlap even makes my LT1 painful at low RPM, the computer does not deal with it well.
Old Dec 3, 2022 | 11:05 AM
  #105
2: Nuclear reactors
I had that cam in my L98 bolton. I was happy enough with it, but it will not play happy with a stock tune.
Old Dec 3, 2022 | 11:28 AM
  #106
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
When it's done I'm bringing it to Kennedy's in Buffalo for a Dyno tune
Old Dec 3, 2022 | 11:37 AM
  #107
skinny z's Avatar
Interesting.
In a carbed application I've managed 71° of overlap reasonably well. While the idle vacuum wasn't great at 10" @ 850 RPM, most of that I put down to very worn shortblock. Cranking compression was down better than 25% across the board. The static compression ratio wasn't ideal either.
I suppose tuning is relative. With some tuning software/hardware the adjustments are easy and infinite. Others, maybe not so much. With a carb and mechanical distributor, the adjustments are infinite but incredibly cumbersome.
Old Dec 3, 2022 | 12:47 PM
  #108
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Long tube runner tpi will still run way out of breath by 5000 or so. Cam might help it hang on some but not enough duration on the lpe 211 to get there. 5500-5600 needs shorter runners. Siamesed could help.
ran the hot cam clone from lunati on a L98, with big mouth tpi parts. Ran well. Required abit if tuning but wasnt hard at all. Ran good idled well and made ok power. It really needs short runners to work well like the lt1 intakes. It will make like 270’s whp on a tpi intake afr 180 head l98 at like 4400-4500 and on a tfs 195 lt1 6 spd car it makes 355 at 6200-6400. Lol so much power on the table
hell even the stock headed automatic lt1 with comp 220/230 cc305 cam made 300 whp at 5800-5900.
Thats why i dont think tpi cams really matter, the intake really controls what happens. Its gonna have a strong wave tune in that 4400 range. So cam doesn’t need to be big but sometimes over camming can help hold some power out beyond 4500-5000.
Old Dec 3, 2022 | 03:37 PM
  #109
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm just looking for fun in the midrange and off the line hops. I enjoy coming off an on ramp and hammering down in 3rd through 4000. Nothing stupid because in the idiot province I live in you'll lose the car. I don't think I'll ever be up over 5200. I won't be racing it. It's a parking lot cruise night car really. And I do take for fairly long drives too.
Old Dec 3, 2022 | 08:37 PM
  #110
Originally Posted by skinny z
Interesting.
When I say low RPM, I mean basically anything off-idle to about 1700rpm. The engine HATES, and barely makes enough power to get out of its own way. While I can run the car in 6th gear at say 60mph, there is zero acceleration on-top unless I downshift. I usually keep the car in 5th gear until I'm consistently above 70mph. My car is running an M29 T56, with 3.23's, so the lower gears like 1, 2, and 3 are very widely spaced, makes the car feel slower than it is on the street because it falls out of its power band anytime you don't ring it out to 7000 on the upshift.
Old Dec 3, 2022 | 10:52 PM
  #111
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Thats why all the stock cams have short duration and very wide LSA on the L98 and LT-1 and LT-4 efi cars.
Typical driver wants to drive at very low engine rpm in the highest gear possible and have it pull smoothly on throttle.. "drivability"
When you cam it up with increased valve overlap you need to change the driving to keep the engine rpm up.
Adjusting the conputer's "tune" by adding timing at idle and low rpm yet keeping the same max spark timing above 3000 rpm when at WOT will help a lot.
The added idle/ low rpm timing helps offset the "egr" effect of valve overlap.
Just like on a cammed up carb engine.
The slop of the rpm based timing curve has to be shortened.
Old Dec 4, 2022 | 10:02 AM
  #112
skinny z's Avatar
A high stall converter here makes a drivability difference too. While I could idle away from a traffic light without too much RPM, if there's any heavier throttle input, it'll climb in revs against the converter and get into more of the torque. Sort of like a CVT transmission.
That said, with the lockup on the highway and OD, revs at 75 MPH were 2500 and 1850 @ 55. It certainly didn't lug up a long grade but that's where the detonation was most noticeable. I tended to release the TCC in those situations. I never did get around to working on the timing in that particular spot before there engine unraveled.
327???
Dec 2, 2022 02:12 PM
WinnipegGTA
Alternative Port EFI Intakes
Feb 3, 2007 01:54 PM
zdrag28
Feb 11, 2005 02:06 PM
cali92RS
Apr 5, 2004 06:59 PM
Justy
Jan 22, 2001 01:59 PM
