Temp gauge moves wrong way
Old Dec 5, 2022 | 06:31 PM
BadHabit's Avatar
Car: 1989 TPI Formula, 1984 MCSS
1988 Camaro 305 TPI.
Instead of the gauge moving up from 100 to the 220 range, it moves down until the needle hits its travel limit.
It was working properly a few days ago so it was capable at some point.
Typical testing (green sender wire to ground, needle pegs to 260+) shows opposite of what it should do.
Now, it's green sender wire to ground, the needle drops below 100 to its travel limit.
Crank and warm up engine, needle travels south at a normal rate until it hits its limit below 100.
My best guess is bad gauge since it started overnight.
All other gauges on that ground circuit function properly, plus no wiring work has been done.
Any ideas??
Marc Webber
Apr 24, 2018 06:50 PM
calgutie
Jun 17, 2012 08:14 PM
BlckSunshineZ28
Jul 19, 2008 07:46 PM
Jaime-TA-84
Jul 11, 2006 12:21 PM
Red L98
Nov 30, 2000 07:58 PM
