Temp Gauge not working
Old Apr 9, 2018 | 06:42 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
Everything on my dash works as its suppose to except the Temp Gauge. When I start the car the needle goes back and fourth a couple of times but after that it never moves while the car is running. The sending unit is new. I checked the voltage on the wire that attaches to the sensor. Shouldn't that wire be hot if the switch is on?
Old Apr 9, 2018 | 11:37 PM
Drew's Avatar
Re: Temp Gauge not working
Camaro? Firebird? Year? If it's an 82-89 Camaro, are you sure the needle isn't stuck? They like to do that, the needle swings too far on the "bulb test" and sometimes the needle will stick on the gauge face.
The sender varies the resistance to ground. Best bet would be to follow the diagnostic chart in the Service Manual.
Old Apr 10, 2018 | 04:38 AM
Car: !982 Trans Am
Axle/Gears: 3.08
It is a 1985 Trans Am.
Old Apr 10, 2018 | 09:06 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
If you ground the wire it should max the gauge. Did you accidentally buy the idiot light sender not the gauge sender?
Old Apr 10, 2018 | 11:46 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sounds like it’s the gauge since the sender is new.
Old Apr 10, 2018 | 12:16 PM
midias's Avatar
You can get a POT and test the gauge I think this chart is right if not it should be close enough to test. Just ground the sender wire through a resistor or POT
Old Apr 12, 2018 | 03:38 PM
Car: !982 Trans Am
Axle/Gears: 3.08
What do you mean by POT?
Old Apr 12, 2018 | 03:39 PM
midias's Avatar
Potentiometer
Drew's Avatar
Potentiometer. AKA Rheostat. Like the dimmer on a light switch.
Old Apr 12, 2018 | 03:40 PM
Drew's Avatar
Dammit! Second time in as many days I've been treed.
Old Apr 24, 2018 | 06:50 PM
Car: !982 Trans Am
Axle/Gears: 3.08
Update its fixed, had the wrong sending unit.
Rigostyle
Dec 17, 2013 07:33 AM
Metallicelmo
Nov 26, 2008 04:28 AM
90IROCJustin
Sep 6, 2006 12:16 AM
z28z34man
Apr 3, 2006 07:52 PM
