Replaced hood struts and started on fuel regulator
Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
Re: Replaced hood struts and started on fuel regulator
Originally Posted by topduarte
Loosened runners bolts (had to break them as I believe nothing on the engine has ever been apart).
Lucky I have a nearly new tpi unit from an 90 9k mile vette.
Adjustable fuel pressure regulators were not factory, so if those pictures were clicked during disassembly, and it looks like they were, then it does appear to have been taken apart in the past. Some people have drilled and tapped the factory regulator to make it adjustable, but yours isn't that. If your other TPI unit has the fuel rails and regulator, then take a look at it. If its regulator is still stock, then it will look like this:
Is that Broken Electrical Connector Black or Grey in Color?
It sure looks gray but should be black. Ive never had good luck with the green map sensor connector, if they've spent any time under the hood, snap goes the tab. Never broke the red tps or iac connector.
