Fuseable links
Old Jan 16, 2023 | 01:12 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Fuseable links
Been thru 100 posts on Fuseable links. I've learned the D battery sized one on the positive battery cable isn't one. I've also learned that there should be one by the starter. I can't find any! Can anyone pinpoint their location?
Old Jan 16, 2023 | 01:19 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Fuseable links
You're probably looking right at them. They're just different colored wires with an inline connector, then the wire changes to the color it's supposed to be in the manual. They are literally just wires that burn up first as though they were a fuse.
Old Jan 16, 2023 | 01:33 PM
skinny z's Avatar
Re: Fuseable links
In our third gens, the splice is the giveaway. It'll appear as a small cylinder between the link itself and the field wires.
Shown below is a melted version.
Old Jan 16, 2023 | 02:36 PM
Engine: 5.7 l98
Re: Fuseable links
can you pinpoint locations?
Old Jan 16, 2023 | 03:00 PM
skinny z's Avatar
Re: Fuseable links
They will be connected to the big positive binding post on the starter. The same post that has the large gauge cable coming directly from the battery.
Old Jan 16, 2023 | 03:03 PM
skinny z's Avatar
Re: Fuseable links
Remember that we're talking about vehicles that are pushing 40 years old. There could easily have been dozens of "wiremen" in before you and possibly hacked them out.
I've done similar with my own ride although the wire routing and method of fusing are not at all OEM.
Old Jan 17, 2023 | 09:58 AM
Engine: 5.7 l98
Re: Fuseable links
possible but I have owned since 96 , hoping there just illusive
Old Jan 17, 2023 | 10:01 AM
skinny z's Avatar
Re: Fuseable links
Total length is less than 6" with one end landed directly on that large starter stud.
My 86 had three IIRC correctly. Two for sure but it's been a while since I've had to deal with them.
Old Jan 17, 2023 | 10:08 AM
Engine: 5.7 l98
Re: Fuseable links
appreciate the help,, going back to take alook now.
Old Jan 17, 2023 | 02:51 PM
Engine: 5.7 l98
Re: Fuseable links
that's right where they were , forward of starter, just missed them when I previously looked, thanks
Old Jan 17, 2023 | 07:55 PM
skinny z's Avatar
Re: Fuseable links
Excellent.
apie2546
Nov 19, 2014 11:56 AM
dangles777
Feb 4, 2008 03:27 PM
Scottlb9
Mar 15, 2007 11:46 AM
