What is this? Something to do with the gear shifter?
Old Mar 23, 2023 | 02:17 PM
LitosWay's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
When I press the gear shifter even with the car off, it lets me shift anywhere from park to drive but shouldn’t the shifter not move if the brake pedal isn’t pressed?
I also noticed when I press the gear shift button the little thing inside the housing goes in but I included a video to see. I looked on diagrams and on the forums here but I can’t find it. Thanks!
Attached Thumbnails What is this? Something to do with the gear shifter?-097a7a06-c0f1-477d-8aa2   What is this? Something to do with the gear shifter?-2aba61e7-3426-4a60-9282
File Type: mov
Old Mar 23, 2023 | 02:38 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: What is this? Something to do with the gear shifter?
These cars have no interlock between the shifter and the brake like a modern car does, but they DO have an interlock between the shifter and the ignition. That unit you show is supposed to be mounted to your ignition switch, to keep you from being able to shift into Park unless the key is in the lock position. It also prevents you from turning the key to the lock position unless the shifter is in Park......
Old Mar 23, 2023 | 05:27 PM
LitosWay's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Thanks that actually helps a lot and would explain some other issues😂
perg
May 16, 2022 03:20 PM
sonu1975
Jul 17, 2012 07:06 AM
snapsmagee2000
May 23, 2010 12:45 AM
beaner67
Jan 29, 2009 12:10 AM
firechicken_-54
Sep 3, 2003 11:51 AM
