Changed to short shifter, gear jumps to neutral in second and forth gear !!!
SubscribeI have a Camaro 91 V6 3.1L 5-speed and I changed my stock shifter to Hurst short shifter.
Hurst short shifter works well in 1, 3, 5 and reverse gears. Problem is in the 2 and 4 gear. I have to shift the gear twice to get it in 2:nd gear and the same with the 4:th one. The first time it always jumps into neutral so I have to pust it harder to get it in 2 and 4 gear.
My stock shifter worked well in all the gears.
Does it have to do something with the shifter stop bolts ?
Any help would be helpful
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:91 Times in 88 Posts
Yes. Loosen the rearwards bolt.
Shift firmly into 4th and hold it.
Thread the stop against the shifter stick and lock it in place.
Repeat for the 135 stop.
