Smoke
Old Jan 21, 2002 | 01:34 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Smoke
My car lets out a puff of smoke when I cold start it. Is this ok? Is there something wrong? When the engine is warm and I start it it doesn't puff out smoke. It doesn't puff everytime I cold start it but does let out a puff every other day or so.
Old Jan 21, 2002 | 01:35 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Your engine is fine
Old Jan 21, 2002 | 02:02 PM
ChevalierSS's Avatar
It is normally caused by a small leak in the valve seals. Nothing to worry about as long as you aren't losing a lot of oil.
Old Jan 21, 2002 | 02:06 PM
sleeper's Avatar
The seals leak oil down the valve stem as the car sits overnight. This happens to all small block Chevy's as they get older. When the head heats up it expands and seals the leak.
Wait untill you have a reason to remove the heads and fix the seals then... a small leak won't hurt anything. Don't let some mechanic tell you you need a rebuilt head or engine or something.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
