406 SBC starter troubles
Car: 1983 Camaro
Engine: 406 sbc
Transmission: Turbo 350
Hey there just throwing out a problem I have been having.hopefully someone has more insight.So I have a 406 sbc interally balanced with a neutral 350 balancer and flywheel of which I believe to be 153 tooth.my problem is my starter bolts up but isnt happy seems to be only engaging the end of the starter gear. It is a staggered bolt pattern starter.would an aftermarket starter with a universal mounting be my only option at this point
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: 406 SBC starter troubles
IIRC,earlier blocks,prior to about 1978,never came with 153 tooth flexplate-causes starter fitment problems,may need to use168 tooth flexplate or special starter.
Engine: 4++,350 & 305 CIs
Drilled and tapped my block for the smaller starter.
I use a 92-96 corvette starter.
if you have a 153 tooth flexplate/flywheel, you need a starter with an inline mounting pattern. the staggered mount starters are for a 168 flywheel. hope this helps
RPOL98 (05-25-2023)
Ask Sofakingdom. He might make a sticky for the manual trans 153 tooth flywheel 400 sbc combo.
Received 1,714 Likes
I can't make stickies. ![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Just search my userID for this topic. I've posted about a million times what the problem is and what the solution is and more importantly what it is NOT, with photos, measurements, and so on; all taken on a 1973 3951509 block. I'm tired of typing it.
RPOL98 (05-26-2023)
