383 starter problems.. help!
Old Sep 22, 2002 | 08:36 PM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
Well the ONLY thing holding me back now is the starter.. Of course my stock 350 starter will not work because of the 168 tooth flexplate... I went to OReily and bought a starter for a 400 sbc 1980 chevy truck.. It fits, BUT the bolt hole in the block closes to flywheel is a DIFFERENT size than the other 2 starter bolt holes.. It makes NO SENSE.. seems like its the size of a head bolt. Anyone every heard of this?
The 400 starter is HUGE also.. very close to my headers...I'm thinking about taking it back and getting a mini starter.. with 10.25:1 compression, i might need a higher torque starter anyway..
What do yall think ?????????????????????
Old Sep 22, 2002 | 08:45 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
sounds like you need another starter
Old Sep 22, 2002 | 08:49 PM
boogie's Avatar
Sounds like someone stripped out that hole before you and maybe drill and tapped it to 7/16.
Old Sep 22, 2002 | 10:00 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
i emailed the engine builder and he said use a staggered starter for a 168 tooth sbc..
the one im using wasnt staggered, so maybe thats the problem. I still dont see what the point of having two bolt holes an inch apart is though if only one "works"
Maybe the other was drilled /tapped to something bigger?
shane
be ordering a hi troque mini starter soon
Old Sep 23, 2002 | 05:04 PM
Fast3rdGen's Avatar
do what i did.....i used a 4.3v6 starter for an 88 s10. its tiny as he!! for great header clearance and has a staggared bolt pattern and works with the 168 tooth flywheel. thank got for Jay at the local NAPA beeing an ex-roundy round racer and telling me about that little gem. :hail: :hail:
Old Sep 23, 2002 | 05:41 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
already ordered a hi torque mini starter off ebay... $100, but ac delco brand and brand new with a 1 year warranty.
sounds like a good deal you got, but i'd just be worried it wouldnt like my 10.25:1 compression ratio in the log run.
Shane
Old Sep 23, 2002 | 05:47 PM
Fast3rdGen's Avatar
Shane
didn't ya read the part about they guy recomending them was a roundy round racer? he was using them to crank over 12.5:1 motors easily. they are some kind of magnetic type starter that makes more torque than a standard gear reduction starter.
Old Oct 1, 2002 | 03:02 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
Well i tried using the 4.3 liter v6 starter for a 88 S10, it smoked trying to turn the motor over. not near enough power for my 10.25:1 383 stroker.
Cant imagine people using this on a 12:1 compression motor..
It turned it over VERY slow, and stopped ever few seconds. Guess i'll try the hi torque mini starter now..
I didnt have the a/c delco starter, i had a "ultima" reman from hi lo oreily... $100
Shane
Old Oct 1, 2002 | 04:14 PM
Fast3rdGen's Avatar
sounds like you got a bad one. mine spins it over a hell of alot faster than my high torque starter turned over my old 355.
Old Oct 1, 2002 | 09:13 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
I guess so. I put my high torque mini starter i got off ebay on there, and it turns the motor like nothing.
I hope i can take the other starter back since I had to drill out one of the bolt holes to 3"8.
3rd gen money
Oct 11, 2019 09:57 PM
LT1Formula
Oct 8, 2015 08:34 PM
